First post, by gerwin
- l33t
I kinda like these geforce 6200's as they are affordable, compatible, not too slow and don't require active cooling. They are actually the first reasonable successors of the Geforce MX440 (DirectX7), as the FX5200 is too crappy.
I only have one such card, an AGP card from Asus with 256MB. This particular one ruins 'suspend to ram' mode 🙁 , It has a connector that does not fit an AGP 2x slot. Others are seen with a universal AGP connector.
I would like to know if someone had any succes using a certain 6200 model with a 440BX mainboard with windows 98.
There are also PCI versions, which might be interesting because they are independent from an under-spec, or even overclocked, AGP bus. What kind of drawbacks will one experience when using PCI instead of AGP?
6200 is usually found with 64-bit DDR2 250MHz, AFAIK this just equals my MX440 with 128-bit DDR, giving 8 GB/s. I read there are some early variants with 128-bit memory bus support (not the 6200A). Anyone know a model with actual 128-bit memory?.
Some older games might not like the newer card and/or its drivers. Thief and AvP come to mind, but I don't know how severe this compatibility problem actually is.
Finally, since the Geforce 4 or 5 series the Bios dropped support for VESA 3.0 monitor refresh rate adjustments. Is there any way to modify the Bios to re-enable this feature?
(All in all, this 6200 may very well be unsuitable for my retro system)
