First post, by 9mmMick
I downloaded Redemption.wad.
Now how do I get it to work?
Reply 1 of 4, by MikeRS
doom2.exe -file redemp~1.wad
Considering that it has a filename that's not conforming to 8.3, it's most likely not intended for vanilla Doom. Check the text file to see if it requires a sorce port (such as PrBoom, Eternity, ZDoom, Doomsday, or various others)
Reply 2 of 4, by CrisGer
I recall using that for Doom2 ok, did you need to know the proceedure to use DosBox or an emoulator to run a wad? it has been so long for me i would have to review.
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
Reply 3 of 4, by franpa
You also need a REGISTERED doom2.exe file if your are not going to use a source port.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 4 of 4, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
