First post, by wasiliy
http://www.ctyme.com/intr/rb-0136.htm
It seems to write something, but the patterns look scrambled.
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
Example?
Reply 2 of 5, by wasiliy
http://wasiliy.myftp.org/space.zip
"procedure schiffe" contains the patterns and "procedure init_schiffe" is supposed to write the patterns to video ram. It worked back then when I had Windows 98. So I don't think that it's a problem with the code.
Reply 3 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
INT 10/11 works fine, but your program is not managing the segment for the character patterns correctly in the context of a protected mode program. ES is destroyed after the DPMI provider switches to real mode and calls DOSBox's INT 10 handler. Maybe a simple solution is to compile for a real mode executable.
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
Right, the fact that the game is buggy is hidden by w98's dpmi host,
it does not work on a real dos system.
Reply 5 of 5, by wasiliy
Oh, sorry then. I must admit that I've never worked with a real dos system =)
I'll try writing directly to VGA memory.
