First post, by DosFreak
The Pentagram webpage states:
While it is currently possible to finish Ultima 8 using Pentagram, not everything is fully working yet. (Save regularly!) In the game itself, most notably, the combat AI of monsters is still very limited, and there are still quite a few minor things which are not working as well as they should.
Outside of the game, installation and setup of Pentagram still require manual configuration. We hope to eliminate most of this in the future.
but it's stated this for quite some time.
Anyone actually played and finished Ultima 8 using pentagram recently and are the features mentioned above that are missing still missing?
Make your games work offline
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The whole thing is still quite raw, no shiny stuff like Exult features. And you can expect to encounter bugs still. Personally if I'd wanted to play NOW I'd play with Dosbox. But I'm waiting for Pentagram to go further and then play it with that 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
