First post, by emodel
hi
well, i don't know if this is the right description :
For now i have a separate .conf for games and for windows 3.11.
The autoexec section for the one for windows is :
[autoexec]
mount d k:\ -ioctrl -t cdrom
imgmount d ".\drive_C\win311\SPACE\ISPACE.iso" -t iso -fs iso
mount c .\drive_C\win311 -freesize 1000
c:
cls
cd windows
win
For games it's :
[autoexec]
mount d j:\ -ioctrl -t cdrom
#mount d E:\Dosbox\Drive_C\USNFGOLD\CDDATA
mount c .\drive_C\ -freesize 500
c:
cls
dir/w/p
Also, the screen resolution is different (640 for games, 1024 for win).
What I would like is to use a single .conf and define required parameters with .bat file (I use a "start.bat" for each game or app).
For windows "start.bat" I tried :
windowresolution=1024x768
cd windows
win
"windowsresolution" does nothing, and i got an error message for a sound thing.
Questions :
Can we pass a resolution argument in the bat file ? (to change dosbox window or fullscreen size)
Can we overide default mounting (found in dosbox.conf") with those used in the bat ?
thanks
Thanks
Reply 1 of 23, by MiniMax
Rank Moderator
Moderator
Where on Earth did you find that -ioctrl option?
I never use the -fs option when mounting ISO's.
Yes, you can pass parameters to BAT-files.
Yes, changing windowresolution should work. Maybe try it with different output methods.
There is no default mountings in dosbox.conf, only the mountings you put there.
Virtual drives can be un-mounted using mount -u X.
_________________
Reply 2 of 23, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
mount d k:\ -ioctrl -t cdrom imgmount d ".\drive_C\win311\SPACE\ISPACE.iso" -t iso -fs iso mount c .\drive_C\win311 -freesize 10 […]
cd windows
win
My question is, why do you first mount your k drive as d and then imgmount the inner space iso as d? Does this even work without an error?
Things to do to improve your Windows live 😀
change the batch file like this:
mount -u d
SET PATH=%PATH%;C:\WINDOWS;
SET TEMP=C:\WINDOWS\TEMP
win
The set path is important for Windows, so all its programs work properly and %path% is important, so that all the stuff on z: still works 😀 (so I recommend this also for your windows only conf file - I did write this in the Windows 3.x guide on purpose 😀).
Your sound error might just vanish if the proper path and a temp dir are set. If not I'd recommend either reinstalling Windows 3.x according to the my guide Windows 3.1x DOSBox Guide or just reinstalling the sound drivers (also according to my guide and also using the drivers linked to from my guide).
As for the windowresolution do you really need to set this? If you have the proper drivers installed in Windows 3.x the size of the DOSBox window will change automatically.
One more potential problem I see, I'm not sure if you can un-mount an imgmount, so maybe mount the inner space image to e and see if that works allright (I could test myself but I'm currently away on family business, so I can't test it)
Reply 3 of 23, by emodel
Thanks for your replies 😀
Dunno, I copied that from a website long ago.
I, again, copied/paste that, I don't even remember what it does.
I will try when I'm home. No effect with OpenGL, which I use.
I know, but I meant, I'd like to keep my single "dosbox.conf" for games, and just override (using batch) mounted drives there.
Of course I guess I could mount nothing in the .conf, and only do that at the batch "stage".
So I could use my default .conf, unmounting those in the batch, then mounting other drives (still within the batch), I guess...
Reply 4 of 23, by emodel
Thanks for your replies as well 😉
Haha, good question, I have to check when Im home, maybe there was a "#" which I didn't paste here...
Dominus wrote:
Things to do to improve your Windows live :) change the batch file like this: […]
mount -u d
win
Will try that, didn't know about the "path" thing.
I did install win 3.11 using your guide, but that was long ago (just after you wrote it or so).
To be clear, when I use the specific .conf for windows 3.11 (see above), I don't get any error message from windows, all works 100%, it's just when I use my game .conf (see above).
Will check when Im back home if the "path" thing helps.
Mmmm, maybe when it's set to "original" (or whatever it's called, the default dosbox setting for that anyway). But I need the specify resolution as I use scaler=none. I mean I wouldn't need to set it for windows, where my driver is indeed set to 1024x768, but for games where it's 320x240 or so...
I will test this as well, but why would that be a problem anyway ?
Thanks again
Reply 5 of 23, by MiniMax
Rank Moderator
Moderator
I have this great bridge I want to sell you. Really cheap. Special price for you!
_________________
Reply 6 of 23, by Dominus
DOSBox Moderator
Because from what I read about your goal, using one default dosbox.conf and start games and windows from this config. So the problem I see is that when you have started Windows with this batch and then afterwards you want to play a dos cd-rom game you would need to mount either your cd-rom drive or another image to d. So if you can't unmount an imgmount you are stuck.
By the way since dosbox starts so quickly and easy with different config files and the -conf start parameter, I'm not bothering with a setup like you plan to do.
It's much easier to have different shortcuts with different conf files and just quickly exit dosbox and start another instance of it from another shortcut.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 23, by emodel
I might be interested if it's long enough to cross my ocean of ignorance.
I just checked and those options were taken from the dosbox readme, i must have thought (at the time) it might be useful to have those.
Reply 8 of 23, by emodel
Dominus wrote:
Because from what I read about your goal, using one default dosbox.conf and start games and windows from this config. So the pro […]
Ah I see. It's not a problem for me to close and relaunch dosbox, so the problem you mentioned isn't one to me.
I only wanted one .conf, because it's clean and also and mainly because i use a keyboard shortcut to run dosbox (alt+ctrl+d), and as I can have all the directories displayed at start (using dir /w), i thought it would have been perfect this way.
Still, I don't manage to get it working.
I have everything dos related in e:\dosbox, then in a subfolder called "drive_c", I got all of my apps and games.
Then there is a "win311" subfolder in this "drive_c" folder.
Then, windows 3.11 is finally installed in a "windows" folder inside of this "win311" folder.
I did this way, cos i wanted to have my win 3.11 games and apps in a specific windows 3.11 folder, not along with the dos games etc, so those are in their own folders in the win311 folder.
I guess I should mount "Drive_C\win311" as my c: drive, but that would mean unmounting first the c: drive already defined as in the .conf.
When I try to unmount the c: drive mounted in .conf to override it with one in batch, dosbox crashes.
And if I leave ""Drive_C" mounted as c:, windows doesn't find any of the .grp (wasnt only audio.grp, this was just the first one actually), even if I use your "path" things...
Reply 9 of 23, by MiniMax
Rank Moderator
Moderator
I don't think so.
No on my system:
x.cfg =
[autoexec]
mount C .
C:
magic.bat
echo Done
and magic.bat =
mount -u C
_________________
Reply 10 of 23, by emodel
Right, i just tried 0.72 stable and it works, so it's a problem with cvs.
I use AEP build from today.
I tried a few other versions (always from this page) and they all crash.
Should I report something to someone ? 😀
Latest dosbox cvs on windows xp sp3
Reply 11 of 23, by MiniMax
Rank Moderator
Moderator
If you can create a small BAT-file that illustrates the problem, then please do.
_________________
Reply 12 of 23, by emodel
Well, it's about mounting c: in .conf, then unmounting it in batch..., so a batch only will not do.
Any tip on the windowresolution=... batch parameter ?
Tried different outputs methods, but it doesn't help, no effect at all.
Thanks
Reply 13 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
attach everything needed to reproduce it please. I did change the handling of batchfiles a bit. It might be that the file that includes the unmount command is stored on the drive that you unmount ?
Water flows down the stream
Reply 14 of 23, by arablizzard2413
emodel wrote:
hi
Wouldn't you need to do something like "config sdl windowresolution=1024x768" since you're running from a bat file and there is no "windowresolution" command. But yeah it is kinda useless doing it that way.
Reply 15 of 23, by emodel
You're right, the batch file used to unmount c: is indeed on c:, but I don't see why it should be a problem, as at the time it's executed, c: is still mounted 😀
Still, it works with stable 0.72.
As to attach something, it's just "mount -u c:" beeing present in the batch file : instant crash.
Thanks
Reply 16 of 23, by emodel
It doesn't work either. How could it be useless ?
(please note that I always use windowed mode, never fullscreen)
I want interpolation, so I need scaler=none (at least with my nvidia card and output=opengl).
I want double size for games so I need to specify a 640x480 resolution, but I want 1024x768 for windows 3.11.
If I leave "windowresolution=original", then it indeed adapts to windows 3.11 and it gives me the expected 1024 resolution, but for games it gives me a 320 window, so it's unusable.
So being able to chose resolution from the command line doesn't seem that useless to me 😀
Reply 17 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
well you see. after you unmount it file isn't available anymore. however the bat file itself isn't finished yet. there is still an empty last line present probably. I consider the crashing a bug, however it don't consider it a bug that umounting the drive that holds the bat file from that batfile doesn't work as intended.
Reply 18 of 23, by emodel
Oh well, I will continue to use separate conf files for windows 3.11.
Would have been nice to do everything from the batch.
Thanks anyway.
Reply 19 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
the crashing has been fixed. and unmounting the drive which holds the bat file which you run works as well. Just don't expect the bat file to continue after you remove the drive it is stored on.
