First post, by Kreshna Aryaguna Nurzaman
 - l33t
I patched my Privateer 2: The Darkening with solsector's Windows patch, then installed the game on Windows XP Home Service Pack 3. The game runs quite fine, actually. Everything is smooth, but not overly fast.
However, during spaceflight, the MIDI music does not play.
The in-flight music in Options menu (ALT-O) is indeed enabled, but it doesn't play nonetheless.
Out of curiousity, I copied the following files from the CD to my installation folder (C:\DARK)
SETSOUND.EXE
DOS4GW.EXE
AILDRVR.LST
PROAUDIO.DIG
SB16.DIG
SBLASTER.DIG
SBPRO.DIG
SNDSCAPE.DIG
ULTRA.DIG
MPU401.MDI
PAS.MDI
PASPLUS.MDI
SBAWE32.MDI
SBPRO1.MDI
SBPRO2.MDI
SNDSCAPE.MDI
ULTRA.MDI
Then I executed SETSOUND.EXE, and chose MPU401 as my MIDI device. It created a file named MDI.INI, with the following contents:
;;Miles Design Audio Interface Library V3.03 of 18-Jun-95;DEVICE General MIDI (Roland MPU-401 interface or 100% compatible)DRIVER MPU401.MDIIO_ADDR 330hIRQ -1DMA_8_BIT -1DMA_16_BIT -1
Yet the in-flight MIDI music still does not play. What's wrong? Anyone has similar experience before?
Kreshna Aryaguna Nurzaman.
