Problems, Please Help.
First post, by Unregistered
I'm new to all of this so bare with me if I'm a bit slow. I followed the instructions on the Aerowinx PS1 page to install and configure but I can't seem to find the "joy1, joy2, joy3.map" files. I seem to get lost at the part where it tells me to configure the VDMS.INI file. The .INI file that I have doesn't match the one in the instructions. Please help, the page is http://aerowinx.com/html/winxp.html
Reply 1 of 4, by Snover
Ah, that's silly, and old. joy1.map, joy2.map, and joy3.map should all be in your VDMS directory unless someone forgot to package them with the 2.0.4.2 update. *points at Vlad*
Aaanyway, yeah. Just use the LaunchPad, it'll make your life lots easier. 😀
Yes, it’s my fault.
Reply 2 of 4, by vladr
Snover, why not actually check the zip before pointing fingers?
Unregistered, you have failed to update VDMSound. Check the "How to update VDMSound to its latest components" thread on this forum (at the top).
Cheers,
V.
Reply 3 of 4, by Snover
Pointing fingers is fun. And it's good exercise.
Yes, it’s my fault.
