Divide by zero & Boobia City
Reply 40 of 85, by Snover
Okay, here are all the versions of DOS/4GW I found in my massive archive of over 300 games and their associated MD5 checksums:
DOS/4GW EXTENDER
Versions (with MD5 checksum):
1.8 [a63c63f62dadba7163776fbc32ce3fe3]
1.92 [a75fdc120ae2fbb4cb2fd9e7b6a94858]
1.95_1 [498c3f0c7bc7a9206a7b1b049f0c3234]
1.95_2 [15ff24d641ba6ad318362935147bc2fb]
1.97_1 [006211ca60fa3d4b38a9a8da2ade1056]
1.97_2 [ee4033581845b3b8d28c4b7287eb4fc2] *
1.97_3 [fd90468391ade7feb178340c44877e93]
2.01a [ba53625d50570fa897134d57f2da649c]
* This is the most common version of DOS/4GW.
These, and this list of checksums (with filenames), can be found in the attached EXE [RAR/SFX] file.
    dos4gw.exe
    374.34 KiB
    6006 downloads
Yes, it’s my fault.
Reply 41 of 85, by Stiletto
Thanks guys... I had been putting that off and putting it off... and now I don't have to do it! (i.e. find as many versions of DOS/4GW as possible).
do the Fandango!" - Queen
Stiletto
Reply 42 of 85, by Snover
No, you still need to check to see if any of your versions have different checksums, and if so, you need to upload them with their associated checksums. The idea is that this is a COMPREHENSIVE database. (That means it doesn't stop with me.) Sometime in the future I hope to put up a crappy site with all the versions available for download.
Yes, it’s my fault.
Reply 47 of 85, by gil22
1. You can try this: divefix2.zip from here: http://www.filelibrary.com/Contents/DOS/54/26.html
2. "Divide by 0" errors are also often caused by excess speed. You can try slowing down your computer with a program like moslo which you can find here: showthread.php?threadid=44
3. Every once and a while DOS4GW will throw a "Divide by 0" error because of mismatched sound config settings. So if this game has a seperate sound config program try setting sound/music to none.
Good Luck!
Reply 48 of 85, by Snover
Thanks for the tips, gil22! One of the few times I get divide by zero errors with DOS/4GW is with the game "Flight Unlimited". The DOS/4GW program is embedded into the game itself which means that I can't do a swap of different versions. I'd like to see if this divefix program works.
Yes, it’s my fault.
Reply 57 of 85, by Stiletto
I think, to continue working on this problem, we'll need to have the game uploaded somewhere, Robo... Can you RAR it and upload it somewhere? We'll take it apart and put it back together again...
Stiletto
Reply 58 of 85, by Stiletto
Boobia city...
hmmm...
City translates as this: òÄéø
I'm guessing Hebrew as your ISP translates to Goldenlines, an Israel ISP (http://www.goldenlines.co.il)
But the word "Boobia" doesn't translate. And Google only finds 16 hits for it. Help, Robo! Upload it somewhere, please!
Stiletto
