FILES= in config
First post, by colinj
The config file doesn't accept a FILES= statement. How do I specify that I need 70 open files? I do business program development, not games.
Colin G Jameson, Jr.
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox allows opening of 127 files by default.
so maybe the detection by program and dosbox don't mix. We would have to debug the program
Water flows down the stream
Reply 2 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
try that: in the folder you mount as c, coy a text file there with the name config.sys and write the line
FILES=70
in it. Just maybe the game/program is stupid 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 7, by colinj
No, I am the one who is stupid. I just manually counted files and there are 136. Is there any way around my problem, or do I have to close and reopen files? The application is chock full of index files.
Reply 4 of 7, by wd
Rank DOSBox Author
DOSBox Author
files!=open files
Reply 5 of 7, by colinj
Seems to be a lot of stupidity around here. I did what you suggested and it works! Thank a bunch.
Reply 7 of 7, by colinj
Sorry, false alarm. It worked because I created an .EXE module instead of running unlinked .OBJs. The latter requires more files. The config.sys file actually made no difference.
