http://forums.opensuse.org/applications/41418 … talled-rpm.html
message 8
The only "link" in that output sent me to sourceforge which ultimately lead me here.
Every distro has the same *&^)(&)*(Uing problem.  Some group of OpenSource developers hacks out a package/tool/product for whatever reason.  They test it on their own machines, post it somewhere, but wash their hands of building official bundles for distros.  Each distro will add some of those packages while they are new, assign someone to be a "maintainer", they will set up some kind of automated feed for updates, and that's it.  Nobody tests anything after that point.
With the token few exceptions of OpenSource products put out by huge corporations paying developers to work on them, it doesn't matter what package you choose, if the developers don't build official releases for the few distros they use regularly, what gets sent out with the actual distro release is busted bad.
If you want to have a very good laugh and are running OpenSuSE, you should try installing BOINC from the official repositories.  It doesn't work and hasnt' worked in years.  Anyone who wants to use it has to build their own from the official BOINC site.  This is only one example, but it is a good one...nice and flagrant.  Pick any distro you want and a person can find hundreds, if not thousands of examples in the "officially bundled software".
From what I can tell, the RPM for DOSbox should have worked prior to KDE 4.x.  Menu stuff changed.  Aparently the maintainer didn't bother to test.
Then again, should DOSbox be smart enough to know its default directory is the NUL device and issue warning/error?
