First post, by Regin
I tried searching around to see if anyone had experienced this problem before and came up with nothing, so I apologize beforehand if I've somehow missed it...
The issue I'm having is that whenever I play some of the old apogee/3drealms games (commander keen, biomenace, blake stone, etc) and go to fullscreen mode, dosbox slows down to a CRAWL. As in, takes forever just to render a menu screen... I've tried changing around various options with no success. It's awfully strange, because I never have this problem with any other games.
Ideas? : \
Reply 1 of 2, by leileilol
your geforce card is running in a fullscreen 8-bit mode. It disagrees with this color depth so it'll slug down immensly. Only other way is to go windowed, or use a different output mode that's not surface.
Reply 2 of 2, by Regin
Changing the output did the trick. Thanks! : )
