Reply 40 of 207, by hydr0x
wrote:You can delete the .conf file from your profile but you'll need to edit the DOSBox shortcuts in the Start Menu to stop the creat […]
wrote:wrote:Well actually the starting directory/cwd, but yes that is right. That is intentional for portable instalations and people who just like having the configfile there.
The "weird" loading is primary for new users. All old ways are still supported.
It's one of those annoying Vista guidelines. I don't want any config/program files in my user directory, I just want data in there. So it's great you're allowing us to just place an ini in the exe directory. One question though: If I do that before starting DOSBox for the first time, would it still create the ini in my user dir or not? Cause I really don't want it to be there, even if it's not used.
You can delete the .conf file from your profile but you'll need to edit the DOSBox shortcuts in the Start Menu to stop the creation of dosbox.conf in your profile.
While your deleting .conf file from your Profile you may also want to delete the hidden "AppData" directory in your profile as well. 😈 Since you just want "data" in there.....
What counts as data to you?
I misread the post above and thought he was talking about the My Documents folder as there seems to be a vista guideline to put certain program data in there (have encountered it with 2 or 3 apps) which is annoying. I have no problem with config files going into Documents and Settings. After all that's the purpose of that folder.
