FreeBSD + joystick issue
First post, by kejen
Having a problem with the joystick. FreeBSD 7.2, Dosbox .72, USB logitech joystick.
Basically, a good example of what is happening is if I make 5-10 circles with the joystick, and then let go of the joystick, it will finish making the 5 circles on the screen. Almost like the input isn't getting broken like it should. Hopefully I explained it well.
It's not in the operating system since if I cat the joystick device, input stops as soon as I do.
Wanted to check if the problem was with SDL, so started up mame making sure was using all the SDL options, and joystick was fine. Also tried zsnes and joystick was fine there.
Is there anything else I can do to try and track this problem down? Or even better, fix it?
Thanks.
Reply 1 of 16, by kejen
Also tried SDLMame and worked fine. But advancemame has the same issue as dosbox.
Hopefully someone more familiar with joysticks can at least tell me what is going on?
Thanks.
Reply 2 of 16, by kejen
bump
Reply 3 of 16, by boyofdestiny
Have you tried the new dosbox 0.73?
Anyway, in your conf file
in the [joystick] section
does setting
timed=false
fix this issue?
Reply 4 of 16, by kejen
Yes, tried the new dosbox 0.73
Do have timed=false, without that, the joystick drifts hard to the right.
Thanks for the reply though.
Reply 5 of 16, by kejen
Bump....
Anyone have any ideas?
Any others using dosbox in FreeBSD? Has to be someone out there that can point me in the right direction.
Reply 6 of 16, by ih8registrations
If I were an admin, I'd kill your thread for your retarded "bumps."
Reply 7 of 16, by wd
Rank DOSBox Author
DOSBox Author
Bumps usually have the effect of completely ignoring a person or similar means.
Reply 8 of 16, by kejen
Maybe another 700 posts and you'll get there. But to be honest, I'm pretty sure one of the prerequisites of being an admin is to have a user name that isn't reminiscent of a 13 year old.
What am I supposed to do, make a new thread every time my post falls off the front page? I made this thread almost 1 month ago and bumped it twice since then. I can see if I was bumping it every 10 minutes, but I bumped it once a few days later, and then once again almost 3 weeks later.
And why would you claim to ignore someone that came here for help, and is obviously still looking for help?
Reply 9 of 16, by wd
Rank DOSBox Author
DOSBox Author
You should not do ANYTHING to bump your thread to the front page as this is plain annoying.
Reply 10 of 16, by kejen
So just post a question, and if it never gets answered, just forget about it? This is how the dosbox forums work?
Reply 11 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
This is how all forums work xD
1+1=10
Reply 12 of 16, by kejen
Thread bumping is pretty much a standard in all forums.
If the fact that someone bumped a thread a couple times in the past month bothers you that bad, you probably need to get off the computer for a bit. Get some air. Touch a girl or two. There is life outside the dosbox forum.
Reply 13 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
well if we knew how to fix it then we would have posted at the first message or bump.
All DOSBox experts visit this forum daily. There is no need to bump threads.
Water flows down the stream
Reply 14 of 16, by ih8registrations
Yes, "bump" is that.
No.
| If the fact ..
Hah.
Reply 15 of 16, by robertmo
have you tried other OSes?
Reply 16 of 16, by wd
Rank DOSBox Author
DOSBox Author
Should be funny i guess?
