Problems getting Glide Support under Ubuntu
Reply 20 of 24, by wd
Rank DOSBox Author
DOSBox Author
People who use debugger-enabled builds usually are capable of not mixing
their config files so please don't over-emphasize stuff like that.
Reply 21 of 24, by robertmo
This discussion confirms that it may give some problems even to people who use debugger-enabled builds. And those builds may also be used by normal users if they use cvs builds. Also frontends may make a lot of mixing inside config files. It also makes command line options incompatible (what would happen if you type dma=false for example? which option would change?)
It is absolutely not a problem to rename, and there are absolutely no side effects of that.
So why not to get rid of some potential future problems while there is a chance.
Reply 22 of 24, by wd
Rank DOSBox Author
DOSBox Author
That's their problem then.
I don't see any problem with that when using a regular dosbox config file.
Yes it's a matter of getting people to realize what matters and what not.
I'm sorry if it took the guy more than a day to get his config file "fixed",
he surely learned interesting things on his way debugging this.
Because nobody cares.
Reply 23 of 24, by gulikoza
I considered changing the config entry but didn't. Gus uses the same syntax (section and bool named the same), if it also gets disabled when gus::gus=true and log::gus=false then it's a dosbox issue. I do not have curses installed in my dev tree so I cannot test this at the moment...
http://www.si-gamer.net/gulikoza
Reply 24 of 24, by wd
Rank DOSBox Author
DOSBox Author
This would only be an issue if you use a dosbox config file from a debugger-enabled build with a regular build.
