First post, by Farfolomew
 - Newbie
So it seems my Vortex 2 card, the Montego II, contains a header called SPDIF_I25 (I think it's an "I" maybe a 1 though). It's an 8-pin connector, and supposedly you use it with a digital i/o breakout bracket. I bought this card last century, and thus, have no idea where that bracket could be (if I ever had one to begin with).
I would like to be able to use the S/PDIF capabilities of this board to digitally output the sound to my AWE64's S/PDIF input. I have two questions:
1.)Is this even possible IN DOS even if I did have this original breakout bracket?
2.)Since I don't have the above mentioned bracket, does anyone know the pinout of the 8-pin connector, so that I can use a custom cable?
Here's a small picture of what i'm talking about. The 8-pin connector is on the upper right side of the card, with the breakout bracket to the right of the Montego II:
Thanks!
