First post, by hiro5
Just 2 little requests about the internal config tool of dosbox (0.73)...
(in windows)
1.- Change the directory of "config -writelang/writeconfig"
to "capture" dir...
or to %APPDATA%\DOSBOX\
C:\Documents and Settings\<user>\local settings\appdata\dosbox\
actually it writes where dosbox.exe are... and if you don't have the permissions to go to c:\program files\dosbox\... you cannot get the file.. it could be better this way ^^ ...
2.- make sure that you don't overwrite a file when you make config -writelang/config (actually it overwrites)
... or add a option in command line to "overwrite or not".
PD: I don't speak english very well... I hope you understand what i'm saying 😜
By the way,
a BIG THANK YOU for this program, to all dosbox team, and everyone that helps 😉
