Multiple config files
First post, by AMIGrAve
Is it possible to use dosbox in a way that he loads the user's config file ~/.dosboxrc and also load a user defined secondary config file that will override what was set with the default config file ?
That would allow to have all platform specific configuration in the user's config file, and have a dosbox.conf file in each games/demos directory with settings specific to this game demos (eg : autoexec, sound card, cpu cycles)
Actually, it seems that when dosbox sees a dosbox.conf in the current mounted directory it will use that file, but won't load the user's default config first. And I'd like to have the later case. Is that possible ?
Fabien Meghazi
http://www.amigrave.com
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
-conf configfile1 -conf configfile2
Water flows down the stream
Reply 2 of 4, by AMIGrAve
Cool ! Thanks !
Fabien Meghazi
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
The README-file is even cooler!
_________________
Reply 4 of 4, by AMIGrAve
You're right.
Won't happen again.
Fabien Meghazi
