First post, by jadeviki
I use dosbox 0.72 & 0.73
I want record a replay of my saved playing in doom / doom2
(13 years passed -_-;)
to a *.avi file.
but I got a problem : the dosbox windows appears as WIDE SCREEN.
I have 1600x1200 resluition LCD, so I want play just regular size(640x480)
, not wide...
how can I adjust it?
Thanks in advance.
(sorry for my poor English, that's not my mother tongue;;)
jadeviki@nate.com
Reply 1 of 5, by Kippesoep
Since your display is already 4:3, all you need to do is set "aspect=true" in the configuration file.
My site: Ramblings on mostly tech stuff.
Reply 2 of 5, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by HunterZ
What if you're not using a 4:3 display?
Reply 4 of 5, by Kippesoep
Then you'd need some extra settings to get a display at 4:3 in your 16:10 monitor (specifically: fullresolution=0x0 and output other than surface, preferably ddraw [as that also works when machine=vgaonly or with high-colour video modes])
Reply 5 of 5, by jadeviki
thanks~
problem solved~ 😄/
