First post, by slowchild
hiiiiiii
just in search of some help regarding this classic game.
i'm pretty much having zero luck in getting it up and running.
after running 'setup' (there is no actual install.exe only a setup.exe which configs only the video and sound card) sucsessfully i go to play the game but then get the following errors:
Unable to access file 'A:\anms35\button.anp'
(when i type 'bb' into dosbox)
and
Illegal command: checkcd.bat.
Illegal command: checkmem.
(whenever i type 'tony96' into dosbox)
among the folders and files unzipped there is a folder named 'anms35'
which has in it 'button.anp' so it is actually present. also i am unsure as to why it says a:\ instead of c:\.
checkcd.bat i'm assuming has something to do with a cd and checkmem. maybe refers to a memory issue but i quite honestly have no idea.
i'm using the latest dosbox (o.73)
Compaq Presario AMD Athlon XP 3000+ 2.10 GHZ, 768 MB of Ram
NVIDIA GeForce FX 5200
anyway, im pretty new to this whole thing and some help would be much appreciated.
if anyone wants to try for themselves i got it from Link removed by moderator under dos. site seems to be legit as i have downloaded and played a few other games from there with no problems.
thanks
gamespot review of the tony larussa baseball 3 1996 edition
http://www.gamespot.com/pc/sports/tonylarussa … 996e/index.html
Reply 1 of 3, by ADDiCT
Dear lord... Someone, please delete the warez link, close the thread and (this is optional) ban the poster for a feeble attempt at "marketing" a lame-ass pirate website.
To the original poster: your problem is not connected to DOSBox, but to the fact that you have downloaded a pirated version of the game.
Reply 2 of 3, by slowchild
okayyyy...
i'm making no attempt at "marketing" that particular website. the game is extremely difficult to come by these days instore or online. i would email stormfront studios but they have unfortunately closed down. i personally don't have a problem playing this game even if it is slightly dodgey given the fact it is sadly shrinking away. not alot of people play this game or have even heard of it.i would love to play this game again. but good on you anyway
Reply 3 of 3, by mikeawada
I was able to get Tony Larussa 3 '96 Edition to work great with a bit of tweaking.
Seems with the default settings for DosBox and the Tony96 batch file settings, the DOS4GVM memory manager causes problems and the game crashes.
Here are the DosBox 0.74 config file changes that I made:
memsize=32
xms=false
ems=false
umb=false
mount c c:\DOSGAMES
mount d c:\DOSGAMES\CDROM -t cdrom
c:
cd \tony96
I installed the game in the \Tony96 folder. Notice that I don't play the game from the cd-rom, but rather from the harddrive. This simply required copying the contents of the entire cd-rom into the DOSGAMES\CDROM folder, and issuing the above mount command in the config file.
Here is the what I now have for the contents of go.bat and tony96.bat (they are identical) that come with the game:
echo off
if exist *.swp del *.swp
if exist first.tmp del first.tmp
if exist last.tmp del last.tmp
if exist tlrb35.cfg goto frontend
setup
:frontend
echo Tony La Russa Baseball 3, 1996 Edition ver 1.01
call checkcd.bat
checkmem %1
if errorlevel 1 goto end2
:main
rem set DOS4GVM=SWAPINC#1024
main %1
if errorlevel 8 goto end
if errorlevel 6 goto draft
if errorlevel 3 goto bb
goto end
:draft
draft %1
if errorlevel 1 goto main
goto end
:bb
rem set DOS4GVM=VIRTUALSIZE#32768 SWAPINC#1024
bb %1
goto end
:end
rem set DOS4GVM=
mode co80
cls
:end2
Make sure you also copy/overwrite these bat files to the CDROM folder too, because I suspect they are sometimes run from there when the game spawns between main.exe and bb.exe, although I'm really not sure.
Also, make sure that you always run the game from go.bat (and not running main.exe directly).
That should do it!
