First post, by datajerk0
datajerk0
Offline
With 0.73 is it possible on OS/X to startup DOSBox with a non 4:3 aspect ratio? I've tried many combinations of output and scaler without any luck, I always get 4:3. I am using 50.com to run a text-based application and that works great, but now I need to stretch the font.
A better solution would be a native 50-line mode like Windows XP. Is that an option?
Actually a mush better solution would be a Curses-based DOSBox like DOSEMU so that I can use xterm with any resolution/font and have the ability to cut/paste.
Thanks.
