First post, by Major_Blackhart
Hey, this was mentioned by another registered user on this forum post:
Crusader: no remorse wont load 4th mission.
However, when I did a further search, I couldn't find anything relating to a possible solution to the user's problem.
I'm using Dosbox version 0.73. I have an original copy of Crusader: No Remorse, and have installed it properly using Dosbox.
The game was running perfectly until the end of level three. I have the same issue described in the link above, the longer video will play after I teleport, but then after the video completes, there is a blank screen, simply jet black.
I can still hear several sounds, so the game (I'm guessing) has not frozen (the sounds I hear are the E for Energy pack, and M for Medipack sounds).
When I try to skip through the video, even then the screen jumps to black, and it appears that even after several minutes the game simply won't load. I'm at a total loss at this point and am unsure what steps next to take. The game, other than this, runs absolutely flawlessly on my system.
Any suggestions or answers would be most helpful in this regard.
