First post, by PowerPie5000
- Oldbie
Hi all, i have just finished transferring my P3 system into a slightly larger and better looking case! Now when i power the system up i can really hear the CPU fan and it is a bit loud!
I have checked the bios and it does not have any CPU fan options apart from an option to turn off the fan in power saving mode. I checked the fan speed using PC Wizard and it is running at just over 6000 rpm - all the time! I did not notice this when everything was in the old smaller case (maybe it had better sound insulation??).
The motherboard is an Intel SE440BX-2 and i am pretty sure it has smart fan control but i could be wrong? Does anyone else have one of these boards?
