First post, by score_man
OS X Leopard 10.5.8
DosBox .73
20" iMac, Intel core duo
Loaded up. Works fine. dosbox.conf in directory, autoexec works. Nothing, absolutely nothing I put in as resolution commands makes any difference whatsoever. Would like either 1024x768 or, better, 1152x864. Always opens in tiny window. Tried every output, machine, aspect and scaler as well. No difference.
Any ideas what I'm doing wrong?
Many thanks.
Reply 1 of 7, by IIGS_User
tried
scaler=xxx forced 😕
Klimawandel.
Reply 2 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The scaler settings can't be changed by commands in [autoexec].
1+1=10
Reply 3 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
on my imac 24" this works fine to make the resolution get bigger:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=1024x768
[render]
frameskip=0
aspect=false
scaler=normal2x
Just remember to edit ~/Library/Preferences/DOSBox 0.73 Preferences
Reply 4 of 7, by score_man
Thanks all,
Still no go. I'll try it on my old dual G5 and see if I have any problems. Then I'll try a previous version on this machine. It's just too odd, it really ought to be working fine (by the way, it does work fine on my XP machine).
FYI, the only config file which seems to work is the "dosbox.conf" which I have in the same sub-directory (pardon me, the same folder) as the executable. When I alter the ~/Library/Preferences/etc. file no changes at all occur, including in the "autoexec" section.
s_m
Reply 5 of 7, by Dominus
DOSBox Moderator
the Preferences file does not work because you got the dosbox.conf file in the same sub-directory. Doesn't matter much, anyway (just that you always need to edit the dosbox.conf file, not the preferences file).
Copy the dosbox.conf file to another directory and instead of this, copy a new text file there with only these contents:
[sdl]
fullscreen=false
fulldouble=false
[render]
frameskip=0
aspect=false
scaler=normal2x
and then test again...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 7, by score_man
thanks again, I'll give this a try when I get a moment -- probably tomorrow
Reply 7 of 7, by score_man
I tried the scaler=normal2x forced line again and it worked this time. I must have made a typo last time I tried that.
Thanks, now it's working just fine.
s_m
