First post, by PowerPie5000
- Oldbie
Ok i have been searching the net and cannot find a 40mm that uses a "mini" 3-pin connector - is there a certain name for this type of connector?? It is for my old Matrox G400 Max as the current fan is starting to get a bit loud and whiny!
This picture shows the 3 pin connection on the G400 using 2 wires... mine has 3 wires and the same connector.
Does anybody know were i can find a 40mm fan with this type of connector? or maybe a 3-pin to mini 3-pin adapter?? (in the UK) thanks 😀
