Pentium MMX emulation - possible?
Reply 20 of 32, by wd
Rank DOSBox Author
DOSBox Author
Keep us updated about the progress!
Reply 21 of 32, by leileilol
ih8registrations wrote:
Direct X has MMX emulation.
That's more of a MMX-based Direct3D software rasterizer (like its MMX-less cousin "RGB Emulation" but not dirty like "Ramp emulation") than actual emulation of MMX instructions.
Reply 22 of 32, by ih8registrations
No, in InitDirect3D it checks for mmx and sets to mmx emulation if not found. The catch that I see is that it depends on it being enabled at compile time, where the example shows it's disabled.
Reply 23 of 32, by ih8registrations
The sarcasm is unnecessary wd.
Reply 24 of 32, by Qbix
Rank DOSBox Author
DOSBox Author
I currently see no use to have MMX. Who knows about the future, but currently no.
Water flows down the stream
Reply 25 of 32, by Zorbid
Well, I read some more to refresh my memory:
I was wrong about SSE being unable to work on chars. I didn't check it in details, but the SSE2 instructions are advertised as a superset of the MMX ones.
Using SSE2 could be a good option for most cases, but, since the MMX registers and some flags have to be manually cleared before x87 instructions are executed, (http://www.tommesani.com/MMXEMMS.html#), I'm almost certain that, even though not clearing them was risky, some programmers abused the functionality...
Reply 26 of 32, by wd
Rank DOSBox Author
DOSBox Author
There's no sarcasm, and while i don't see any reason for MMX emulation
i'm curious how far you'll get. Especially when using host-wise SSEx stuff.
Reply 27 of 32, by OSH
Maybe we want "so far get", because we need such emulation? I hope, somebody will have a good mind to make MMX emulation in DOSBOX. I'm not a programmer, and I can't but I'm sure this can DOSBOX great improve.
wd, you are DOSBOX creator and I have really much respect for you. But If you haven't time (or will) to make this emulation a reality, why you are so trenchant? Nobody ask you to make this emulation, nobody here bother you, why?
Reply 28 of 32, by Qbix
Rank DOSBox Author
DOSBox Author
well we would have to maintain it if we put it inside the code.
Possibly relying on more dependencies (those libraries mentioned) and probably dealing with more asm in the source tree.
currently the DOSBox team doesn't see need for MMX, how easy or how hard it is to code. Hence we wish everybody success on coding it. but the chances of adding it to dosbox are rather slim, unless it is a very easy and doesn't introduce any new depencies.
Reply 29 of 32, by Zorbid
@ OSH: wd is always very terse in writing, and often sarcastic, but it's not the case this time around, apparently.
Reply 30 of 32, by ih8registrations
Did I say was going to code this? Are you pretending as if I had? No, and yes.
Reply 31 of 32, by Qbix
Rank DOSBox Author
DOSBox Author
Excellent.
Thank you ih8
So I can now safely close this topic.
(as else I feared I might have blocked some attempt on coding it.)
Reply 32 of 32, by HunterZ
A narcissistic response, as it was Zorbid who talked about actually doing it.
Qbix, resume fear since you potentially stomped on Zorbid :p
