Originally posted by Unregistered The sound in Wing Commander III skips quite frequently, and I was wondering if VDMSound would resolve this problem?
Well, if it's the Win9x version that came with "The Kilrathi Saga", then...no because that's a Windows program, not DOS.
If you're talking about the DOS version, then possibly.
Which version?
My sound card is a Sound Blaster 32, and I'm running Windows 98 Second Edition and Direct-X 9.0a.
If you're running Win98, then all that's available to you is the Alpha of the Win9x version of VDMSound. Considering that means it will need more resources running it with emulation than running it "natively", I doubt emulation will help.
