Passive cooling for a 486DX4 100mhz?
First post, by PowerPie5000
Is it safe to run a 486DX4 100mhz cpu with just a copper heatsink? I've been thinking about getting a fan cooler but all the 486 heatsink + fan combo's i've seen look quite small and thin! i'm also not too sure how hot my CPU gets (AMD 486 DX4 @ 100mhz).
I've also noticed that my heatsink does not have any thermal paste.... and i doubt i could apply any as the heatsink fits very tightly on the CPU!
Reply 1 of 24, by bushwack
Depends on the size of the heatsink and any case fans I would say.
My P200 has a aluminum heatsink only but its kind of large (1.75x1.75x1.75 🤣), but it sits just a few inches from the 80mm front case fan blowing on it. CPU stays cool enough clocked up to 290. Good design, less noise.
Reply 2 of 24, by PowerPie5000
My 486 PC never came with any case fans installed and the CPU heatsink is quite tall compared to other 486 coolers i've seen (approx 45mm).
Reply 3 of 24, by Old Thrashbarg
You really don't need much cooling for those things, a decently sized passive heatsink (i.e, average Pentium heatsink, minus the fan) with a little bit of case airflow should do fine. IIRC, even the higher-clocked 486 chips never drew more than 5-6W.
Reply 4 of 24, by Anonymous Coward
Wow a 45mm heatsink on a 486? That's quite nice! I thought I had some pretty nice 486 heatsinks, but they're no more than 18mm tall.
The DX/4-100 is quite happy with passive cooling. That's what intel provides on the overdrive version of the chip.
Reply 5 of 24, by bushwack
Just touch it. If you run it for a few minutes and can't keep your fingers on it, then it's too hot! 😁
Thinking about it, the Voodoo 3 I ran had a passive heatsink and clocked at 166. Puppy was too hot too hang on to but ran fine that hot.
Reply 6 of 24, by PowerPie5000
The tall heatsink on the CPU is warm to the touch... not very hot at all so i'm guessing it's safe 😀
While i'm on the subject of passive cooling, do you think one of these would be good for passively cooling my Matrox G400 Max? It's a Zalman ZM NB47J chipset cooler (looks quite similar to my 486 heatsink).
My Ga400 Max has got a small/thin heatsink and fan on it at the moment which sounds quite whiny.... I know the standard G400 comes with a passive cooler but i have no idea how much hotter the G400 Max is?? Do they even run that hot?
Reply 7 of 24, by Anonymous Coward
Ha, I was looking at that exact heatsink last night. As it turns out, it's the perfect size for a 386.
Reply 8 of 24, by PowerPie5000
It's quite similar to the tall thing i have cooling my 486 (except mine is copper and does not have mounting holes). I'm trying to decide if this Zalman heatsink will be any good with a G400 Max? (i hate those whiny little fans!).
Reply 9 of 24, by HunterZ
I'm pretty sure the 486DX4-120 I had used both a heatsink and fan, but I think the fan died at one point and we used a desk fan blowing into the case to keep it cool enough to run (mostly) stable until we could get a replacement.
Reply 10 of 24, by Anonymous Coward
Intel dx/4 is 0.6 micron
amd dx/4 is 0.5 micron or sometimes 0.35 micron
cyrix dx/4 is 0.65 micron
I would say running at stock frequency, none of these chips should require a fan if the headsink is at least 15mm tall. Overclocking may require use of a fan, especially on the intel and cyrix parts. am486 and 5x86 on the 0.35u process are usually fine when overclocked just using a passive heatsink.
Reply 11 of 24, by 5u3
Even an Intel DX4 at 120 MHz doesn't need a fan, provided the heatsink is big enough.
I dug up an old photo of my 486 box (sorry about the miserable quality):
The heatsink is epoxied to the CPU (speeds up CPU swaps).
Reply 12 of 24, by swaaye
Yeah when I occasionally run the 'ol Am5x86 @ 160, I only have a passive heatsink setup for it. Those are 0.35µ though so they barely get warm. All of those old CPUs only put out a few watts of heat. Consider that the 5-volt 0.80µ DX/2 50 chips were heatsink-optional. 😀
Reply 13 of 24, by HunterZ
Wow the boards look really warped in that pic.
My 486DX4-120 (AMD) must have had too small of a heatsink because it would get really unstable without the fan, especially during the summer when the room temperature approached 95-100 degrees F (35-38 degrees C).
I never tried overclocking it because it's real limiting factor at the time was not being able to do floating point math as fast as a pentium 😀
Reply 14 of 24, by PowerPie5000
I went and got this Zalman chipset cooler to replace the small and noisy cooler on my Matrox G400 Max...... I just hope it does the job!
I removed the fan from the old "flat" heatsink and then ran Morrowind for half an hour to see how much the G400 Max heats up.... It got fairly hot but i could still hold my finger on the heatsink without burning. The original heatsink is very small and flat with a whiny 40mm fan... I'm hoping this Zalman cooler is adequate at passively cooling my G400 Max 😕 (the Zalman heatsink is 47mm tall and will block the PCI slot next to the G400!)
Reply 15 of 24, by swaaye
I bought one of those to replace a mobo chipset active cooler. It is rather tall and will be more than adequate for a G400.
Reply 16 of 24, by dolbytron
486DX4 is a 3.3v CPU and in theory doesn't require any form of cooling,even a 100mhz version...But,it is a good practice to add a passive headsink,any kind/size will be enought. I've got Like 20 of them,and only one is hot in touch...
Reply 17 of 24, by Omarkoman
sorry to revive an older thread but would this work ok on the AMD DX4 100 Mhz ? And how would you mount it ? with a thermal glue (not ideal)?
2025-02-08-06-39-10-Aluminium-Heatsink-With-Without-Adhesive-CPU-Electronic-Computer-Electrical-Cool.png
dimensions are 46mm x 46mm x 30mm which is 1mm over the size of the CPU but that should be ok.
Would I need a fan for it ?
Reply 18 of 24, by MikeSG
If you live in place where summers are hot, and you intend to run the CPU at 100% for long periods of time it needs a fan...
I bought a DX4-100 ODPR recently that was permanantly damaged and no longer worked stable at 100Mhz. Overheat/overvolt damages them.
Modern thermal pads and thermal glue is enough IMO to transfer the heat. They gain 1-5 degrees per second only. Modern CPUs gain 10x that.
Ebay has many 40-45mm heatsink & fan combos. A case fan blowing air directly on it would work too.
Reply 19 of 24, by Omarkoman
MikeSG wrote on 2025-02-08, 14:26:
Thanks for the reply.
I tried to search ebay but cant seem to find 40-45mm heatsink and fan combos.
Any chance you can share a link to one? Thank you.
