First post, by T6600C
Hello, I've lurked here a long time and read things, but I now would like to ask you for help and start participating.
I have been trying to get two games running on my T6600C for about a week now, with little success.
The first is MOO2 (Master of Orion II). This is a fairly late DOS game, but will run easily on my hardware specs. When I tried to install it, it asked for VESA.COM - I got around this by installing it on another machine under DOSBOX and copying the result back. This still asked for VESA.COM. I eventually found the VESA drivers for my machine, and then it errored on DOS/4GW saying that it was dividing by zero. I tried replacing DOS/4GW stub with DOS32A, same error - so it's the code itself, which makes no sense. I tried patching to various patch levels, including 1.31 and the unofficial 1.40 - same errors.
The second game is Jazz Jackrabbit. The version I am trying is the CD version. I install it, no issues, run setup, choose sound blaster, it detects my blaster variable, all is well, and then I go to run the game. It says "Please run SETUP.EXE to configure your sound card". I press any key and it dumps me back to DOS. All SB-related settings do this. It has no Adlib setting. I tried pro audio spectrum and that crashes (my card isn't compatible, just wanted to know what would happen). The only setting that lets me into the game is PC Speaker - which works, but it sucks horribly as half the fun of Jazz Jackrabbit is the awesome music.
This is all with SB compatibility drivers running btw.
I though that my problem was usin' DOS 7.10, but I just set things up with DOS 6.21 and am having the same problems.
I even tried installing Windows 95 on the box (which runs "ok", 486-DX2-66 & 16MB RAM), but it threw VESA errors at me for MOO2 and the vcard apparently doesn't support DX, so I can't run the Win95 version.
Update: I did some thinking and decided that the VESA driver must be bad, and tried searching around again. I found an official Toshiba VESA driver for this machine and it works! This fixes MOO2, but I still can't fathom what's wrong with Jazz Jackrabbit.
Reply 1 of 3, by robertmo
So Master of Orion II works for you.
Why don't you play Jazz Jackrabbit in dosbox?
Reply 2 of 3, by leileilol
Try disabling your "SB Compatibility" TSRs and leave in the SET BLASTER variable, then do the Jazz detection. I assume this is a Microsoft Sound System-based chipset.
DOSBox doesn't fly well on a 486, rob.
Reply 3 of 3, by T6600C
Yeah, I'll give that a go now, but other games refused to detect it w/o it running (tho Jazz is different).
I also have abandoned running MOO2, because while I fixed the VESA problem and the divide by zero problem (related) it runs too slow on the DX2-66 w/ 16MB RAM, and about half of the time the bottom third of the screen is either black or mirroring the top third - between the two it's not worth playing in this state.
Edit: Didn't help (knew it wouldn't 😜)..
I have tested a few more games, Monster Bash detects the SB and doesn't play sound, and fails to detect the Adlib. Biomenace detects both and works great. How is it possible for some apps to detect it and some not to? It makes no damn sense. 😜
I tested a SB16 Value in the box and it works fine with everything, so I'm chalking it up to inaccurate emulation that some games just don't like.
Edit 2:
I decided to wire a cable from the SB to the speakers in the front of the unit, works fine, no volume controller atm tho.
