First post, by SamSeriously
Hey,
i've been experimenting with dosbox and some older dos applications we use at school.
The applications work perfectly, windowed and full screen, so dosbox is really THE solution for me.
Now the prob ... as we use about 15 applications, I wanted to create a shortcut for each, using an unique config for each of the applications.
Now it looks like the -conf in the shortcut isn't read.
The line I use (and I have double checked the location, tried other locations, UAC is turned off, ...) is:
"C:\Program Files\DOSBox-0.73\dosbox.exe" -conf "C:\configs\zanzi2.conf"
The operating system is Windows 7
Tried version 0.72 as well without luck.
The config file is a copy/paste of the standard config, and I can adjust the standard config to act the way I want for 1 application.
The line I get in the status box is:
"CONFIG:Loading primary settings from config file c:\users\gebruiker\AppData\Local\DOSBox\dosbox-0.73.conf"
Any tips or help on this would be more than welcome.
Thanks in advance.
Regards,
Sam
