Hi, ... Alexander
I use your = D-Fend Reloaded, "v0.9.1 RC 1 release", D-Fend Reloaded PortableApps package".
[dosbox.conf, v0.74 "Not Final" Build 2010-1-22]
#           output: What video system to use for output.
#                   Possible values: surface, overlay, opengl, openglnb, ddraw.
#  machine: The type of machine tries to emulate.
#           Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
#            Possible values: 22050, 44100, 48000, 32000, 16000, 11025, 8000, 49716.
Please, ... when dosbox v0.74 released and included, inside your software.
Be sure to update to =
1) Output Values [now = only value] = surface, overlay, opengl, openglnb, ddraw
2)  Machine Values [now = only value] = hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe
3) TandyRate [add] = 49716
4) Windowed Resolution [add] = 1366x760, 1366x768
5) FullScreen Resolution [add] = 1366x760, 1366x768
Also, the [25,28,50 lines] radio button section, "D-Fend Reloaded | Display Section | of a software configuration".
When i run a DOS software, it dont change the text resolution,. it keep always 25 lines.
In example, i select 50 lines in the radio button, and after run a software, and it dont go to 50 lines, in text and also when i try "DOS Edit, software", it dont go to 50 lines in text mode.
See file included, ...
Please verify at your side, ...
