First post, by retro games 100
Hardware:
Asus P2B mobo
"slotket" Powerleap adapter, revision 2. Onboard voltage jumpers set to "1.750V-1.775V" (Is this correct?)
Intel Pentium 3 1000MHz (1000/256/100/1.75v) socket 370; SL5QV
GeForce Ti4200 (not OC'd)
128MB x 2 = 256MB SDRAM
Settings:
BIOS = failsafe values - my best chance of OC'ing success?
Mobo = FSB jumpers set to 120FSB
Mobo = The "turbo" VCore and VIO jumpers set to "Enabled"
Benchies:
Sandra 2002 Pro memory bandwidth = 848, 515
Sandra CPU = 3222, 1618
Sandra multimedia = 6374, 7451
3dmark 2001 s.e. = 7128
Comments:
I could not get 3DMark2001 s.e. to function correctly without setting both the mobo's "Turbo jumpers" (VCore + VIO) to "Enabled".
Reply 1 of 6, by exxe
what rev have the Mainboard?
really a P2B or something like -LS or -B ?
powerleap have two Rev2 adapters the how supports Tualatin (PL-iP3/T) and the other doesn't (PL-iP3)
http://www.powerleap.com/pdf_files/PL-iP3T.pdf
Reply 2 of 6, by retro games 100
On the Asus P2B mobo, it says:
P2B
Rev. 1.12
On the Powerleap adapter, it says:
PL-iP3/T V. 2.0
Reply 3 of 6, by exxe
Rev. 1.12 the newest and supports 100MHz FSB Slot1 CPUs up to P3-900 woth the newest BIOS
you can try a FSB 133MHz CPU, some of the last boards can run PCI/AGP at 33/66MHz at 133MHz FSB
Reply 4 of 6, by retro games 100
I tried a slot 1 1000mhz (100FSB) CPU, and it worked OK. 😀
On this 1.12 board, there's a jumper called AGPFS. Its 2 jumper options are:
AGPCLK=CPUCLK = * 2/3 (default)
AGPCLK=CPUCLK
I'm not sure what this AGPFS jumper does, exactly.
Re: 133FSB CPU, I don't have any at the moment. However, I would be interested to try this. Please can you recommend a P3 CPU to get (from ebay)? Thanks a lot.
Reply 5 of 6, by exxe
the jumper should be the AGP/ FSB Ratio
100MHz FSB and default result in 66MHz AGP but ni idea what the other is
i have some Asus P2B-x Mainbaords but non have this jumper
with you slot adapter you can even try to use a P3-S 1400 Tualatin
i have one on a P2B-B running
wikipedia sas there are 533EB, 600EB, 667, 733, 800EB, 866, 933 and 1000B Slot1 CPUs with FSB 133, just but one cheap and try it
Reply 6 of 6, by retro games 100
Yes, I have tested this mobo with a PL adapter + Celeron 1.4Ghz, and it worked fine. Also, I OC'd the mobo to 112FSB, and it was completely stable.
