First post, by 2Mourty
I have been looking for a cheap 386 motherboard for a while, just won this on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem … e=STRK:MEWNX:IT
comes with a 386/40, but the funny thing is that this board has a vesa slot. Anybody acutally used a 386 with a vesa bus video card? I found this on the internet, and the board is made by the same company...
http://stason.org/TULARC/pc/motherboards/E/EF … CA-34M50HL.html
anyways, I am going to try it out and see how it goes.
Reply 1 of 9, by retro games 100
Unfortunately, I know almost nothing about 386s, but that 386 VLB mobo does look interesting. The stason page says it can run a 80386DX-20 up to a 80486DX2-66, and the cache can go up to 256KB, and the DRAM up to 32MB. Nice find! 😀
I notice that jumper W1 is "Battery type select external/external", and that the J1 header accepts the external battery.
Reply 2 of 9, by 2Mourty
I saw the external battery option too. I am definitely going to use that because I don't know how to replace a barrel battery. What voltage external battery should I use I wonder.
Reply 3 of 9, by PowerPie5000
I'm just using an external 3V lithium cell and it's working fine 😀 the original battery was a 3.6V barrel type but i removed it before it got a chance to leak everywhere.
Reply 4 of 9, by 2Mourty
Thank you for the tip, I will be getting the board by Friday, I will experiment with the external battery.
Reply 5 of 9, by SquallStrife
In reality, it's a 486 board. The Am386DX-40 has a 32-bit data bus, though, so it can act like a 486, including suporting VLB.
Reply 6 of 9, by 2Mourty
How do I get this barrel battery of the motherboard? Just rip it off? Some acid has started to leak out of it, luckily it hasn't touched any of the components, but I want to get the battery of as quickly as possible.
Reply 7 of 9, by Anonymous Coward
You can clip it off if you like (with some sharp pliers), or you can desolder (the way I like to do it). I highly recommend cleaning up the spilled acid with cuetips and strong isopropyl alcohol.
Reply 9 of 9, by Amigaz
2Mourty wrote:
I found this CMOS battery on ebay. It is a 4 pin connector like the battery connector on my motherboard. Think this might be a good match?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem … e=STRK:MEWAX:IT
That's a 4.5v battery which will be thw wrong voltage.
What you should buy is a 3.3V battery
