First post, by ux-3
I can run WC on my SB16 using Soundblaster settings.
I have a DB60XG clone.
I run GSPLAY MT32 and get a positve ok.
I set WC to use MT32.
When WC is started, it never reports that the expanded memory is fully used but freezes the machine (no more CTRL-alt-del).
What am I doing wrong?
Thanks for help
Reply 1 of 6, by robertmo
I think Wing Commander 1 needs intelligent MPU-401 interface. Try DOSBox
Reply 2 of 6, by Amigaz
Please post your machine spec and dos config
Also please post in the Marvin section to avoid Dosbox "spam" 😉
Reply 3 of 6, by robertmo
He posted in the right section. Read its description again.
Reply 4 of 6, by ux-3
Thanks for replies!
You mean, a SB with DB is not able enough? Uart won't work?
robertmo wrote:
Try DOSBox
Why? To clarify the uart or intelligent mode business? I can play the game alright, I want to hear the music on my DB. For that, Dosbox wont help.
@Amigaz: What specs would matter? The game works with FM Synth and has enough ram and EMS. Are you asking for the SB Dos configuration? Does it matter for WC1 ?
Reply 5 of 6, by robertmo
yes in dosbox you can compare whether it works with both uart/intelligent.
You may also try running dosbox on a PC with isa slots. Don't know whether there are windows drivers for Yamaha DB60XG, but maybe standard mpu-401 driver will be enough.
and post your pc specs as amigaz asked, as he asked about it not without a reason i guess.
Reply 6 of 6, by Amigaz
hell, yes! hehe 😀
