Crimson Skies and XP??
First post, by unlucky
hey is there a reason a Micosoft made game wont run in XP?
anyways heres the problem,
after a try to launch the game, all that happens is the begining art pops up (not the launcher). And thats it, it doesnt go beyond that. Also when i ctrl+alt+del it does not show in my active programs.
System Specs,
AMD 1800xp
Soyu Dragon Ultra Mobo
512 DDR
GeForce 4200 128
Windows XP obviosly 😉
anyways plz help
ps i also have this problem with StarLancer, another older M$ game...
Reply 1 of 4, by Nicht Sehr Gut
Originally posted by unlucky hey is there a reason a Micosoft made game wont run in XP?
Because it was made for Windows 9x, which is significantly different from XP. Really. That's all it takes, it seems.
While other people have had some problems, I haven't heard of anyone with this problem.
Can I presume that it's been patched to v1.02?http://www.microsoft.com/games/crimsonskies/downloads.asp
You might want to confirm that your CD is still good by testing it on a friend's PC, especially if they're using Windows 98.
You might try changing video resolution and disabling and shutting off EAX if you're using it, as suggested here:
http://groups.google.com/groups?hl=en&lr=&ie= … ie%3DISO-8859-1
It apparently also has a stick problem in XP. Appears that Starlancer running in XP is pure "chance":
http://groups.google.com/groups?hl=en&lr=&ie= … %3DN%26tab%3Dwg
It doesn't appear that there were any patches for Starlancer:
http://www.microsoft.com/games/da/starlancer/downloads.asp
Reply 2 of 4, by dudalb
"Crimson Skies" runs fine on my XP computer, no problems. Maybe it is a video card problem.
Reply 3 of 4, by Fallow
I can't run CS with hardware video either.
Software works fine but looks superpixelly, hardware gives graphic errors on text.
XP pro, geforce 8600. Tried 98 compatibility-crashes, tried 2000 compatibility-text glitches, tried setting desktop graphics all over the place-no help, disabled visual themes-no help.
