First post, by mbd33
mbd33
Offline
I'm curious.
I'm curious.
wrote:I'm curious.
If you try to format the hard disk image under MS-DOS guest (or any other version of DOS) using DOSBox, all of the data is lost.
Believe me, when I first setup the hard disk image under MS-DOS guest, a partition had to be created and formatted.
if you mount a drive you can't format it.
Water flows down the stream
Oh.
