First post, by vlask
Decided to make 2nd testing platform for mine graphic cards testing. Got Asus PVI-486SP3 mobo from friend (still even dunno if it works), which has everything i needed (PCI,ISA,VL-Bus on one platform). Now i dunno which cpu to use - have here AMD K586-133 (not sure about mobo support), Intel and AMD 486DX4-100 and some older cpus like a intel dx2/66 or dx2/50, UMC Super 40. Want test everything that will work on it - especialy wanna see diference between ISA/VL-BUS and PCI cards. Will use DIAG, PCPBench and Quake 320x240/360x480 resolutions.
Some info about mobo i found here
http://stason.org/TULARC/pc/motherboards/A/AS … PVI-486SP3.html
Now questions
1]which CPU i should use to have comparative results and big chance to get most VLBus cards running
2]How should i set jumper for
VESA WAIT STATE CONFIGURATION - 0 wait states or 1 wait states
3]How should i set
BUS SPEED CONFIGURATION - <= 33MHz or > 33MHz (this refers to cpu frequency or bus speeds?)
4]How should i set
DMA CONFIGURATION - DMA 1 or DMA 3?
5]any suggestions about testing environment? at Athlon XP i used pure dos from win98 start menu, without ems or himem or any drivers. Using fastvid isnt helpfull on 486 or is?
6]if anyone wanna test in any other software, tell me.
Not only mine graphics cards collection at http://www.vgamuseum.info
