First post, by caustic
Hi there! I 'm using an intel pentium 3 - 450 Mhz cpu based pc , with 64Mb Ram (!!!) and a crappy Soundmax 16-bit audio card and windows 98 se. I have installed vcredist without any problems and reboot a few times now , downloaded the latest.zip files and pasted them in the vdm directory but everytime i run the install file , i get an ms dos window with "out of environment space" as the first line , then 14 lines with "bad command or filename" , "installation complete" line beneath them and "please edit c:\autoexec.bat ....." after , which I have done. Is there something wrong in what I 'm doing or any way to work around this?? Please let me know what do i need to do after this has finally been installed. Hope u can post a reply soon!
