Can't copy Glide2x.ovl
First post, by Snover
Paul, any idea why Glide2x.ovl is no longer being generated when GliDOS starts on my system? This is probably an OpenGLide issue but since I haven't really got any Windows Glide games to test with at the moment I can't make such assumptions. OpenGLid.INI and OpenGLid.LOG are both generated fine.
Yes, it’s my fault.
Reply 1 of 9, by Glidos
No, that's not OpenGLide; definitely a Glidos problem. Does it give an error message saying it can't? Is the Glide2x.ovl present in the Glidos folder. Could your glidos.ini file be pointing to the wrong folder?
Reply 2 of 9, by Snover
It doesn't exist in the GliDOS directory -- it doesn't generate at all. The error I get when I try to run a game is that it can't copy Glide2x.ovl to the game directory (for obvious reasons -- it doesn't exist!)
Yes, it’s my fault.
Reply 3 of 9, by Glidos
Ah, its just gotten deleted somehow. Just reinstall Glidos.
Reply 4 of 9, by CraigG
Best get some sent to you, then 😉 Again.
We got new post office owners, and Paul got his this time.
BTW, they look good on this Radeon with 6x FSAA, and 16x AF 😎
Athlon 64 3000+ stock
MSI NForce 4 K8N Neo Platinum
2Gb RAM
nVidia Geforce 6800GT stock clocks
SBLive! Platinum + Audigy ZS2 Drivers
WinXP Pro SP2
Reply 5 of 9, by Snover
I can't use the latest OpenGLide with the OVL that comes with GliDOS. And I thought it was supposed to be generated by Glide2x.dll?!
And, thank god for the new owners, heh.
Yes, it’s my fault.
Reply 6 of 9, by Glidos
Its not generated from the dll. It does entirely different job.
Why can't you use it with the latest OpenGLide? What happens?
BTW, what is the latest OpenGLide?
Reply 7 of 9, by Snover
version mismatch.
Yes, it’s my fault.
Reply 8 of 9, by Glidos
Shouldn't be. That particular interface doesn't really change.
Reply 9 of 9, by Snover
version mismatch, nevertheless.
Yes, it’s my fault.
