First post, by Unregistered
I just get an error message from Windows Installer that says it can't open the package. I'm on Win. XP home edition. Doesn't it work in XP?
Reply 1 of 3, by Nicht Sehr Gut
Originally posted by Unregistered I just get an error message from Windows Installer that says it can't open the package. I'm on Win. XP home edition. Doesn't it work in XP?
Since It it specifically says that it supports it and a large number of people are running it on XP...Yes, it works in XP.
My question is why did you jump to that conclusion? When you download something and it won't open or run, the most logical deduction should be that the file is corrupted; either before or during the download.
Try downloading it again. If it still won't open after download, you might have to try downloading it from a different site.
Reply 2 of 3, by MajorGrubert
Do you have the exact error message that is shown by Windows Installer? As Nicht pointed out, ii could be a corrupted file, but you can also have a problem with directory permissions like the one described in this thread
Regards,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Reply 3 of 3, by Unregistered
Before I got to read your comments it turned out that the file was indeed corrupted. It worked after the third or fourth download. Thanks anyway. 😀 😀
