First post, by marzsyndrome
Was just taking a look at Tyrian 2000 and the Soundblaster Live! patch for it lately.
One thing I've discovered is that (after installing the patch) under DOSBox the Setup program will fail to detect the sound card for sound effects (but music will still work just fine). The only reason I'm interested in getting this patch to work is that (to me at least) it looks like it patches more than just SB support, judging by the amount of new files it replaces....
21/09/1999 14:47 35,780 Cubetxt1.dat16/09/1999 11:24 1,168 default.pal06/11/2000 10:41 402,959 file0001.exe21/09/1999 14:47 9,600 Levels1.dat08/11/2000 21:28 5,866 license.txt03/12/1999 19:39 18,432 Palette.dat07/11/2000 18:16 2,170 readme.txt06/11/2000 10:41 133,546 SETUP.EXE13/01/2000 20:21 156,961 Shipedit.exe23/09/1998 21:49 45,272 STKRUN.EXE11/01/2000 18:44 1,140 Tyrian.cdt02/11/2000 11:22 295,669 Tyrian.hdt04/12/1999 13:07 369,893 Tyrian.pic10/01/2000 23:14 269,616 tyrian.snw03/09/2000 13:07 393,938 Tyrian3.lvl11/01/2000 16:06 96,285 voices.snw12/10/1995 04:36 188,275 voicesc.snw
The readme.txt states at the start "Version 1.3, October 30, 2000" though upon startup of file0001.exe it reports "Tyrian 2000 v1.1". It's just this need I feel to get the program as generally up to date as possible. Unfortunately it's not simply a case of replacing the exe's and expecting it to run afterwards - it expects those *.snw files as well. Tried as I have in comparing two tyrian.cfgs between the old Setup and the new Setup executable, hex-editing what I need to edit, and on another occasion replacing the *.snw files with clones of the equivalent *.snd files, it seems the new program has been coded to read SB support very differently and I can't get the SFX to work still.
I wonder if there's another way around it, or if there's a chance DOSBox may add Live! emulation sometime in the future?
