First post, by Antnyhay
Hello just got the dos box and trying to run Simon the sorcerer which of course is a ms dos game i am able to install and run it the first time and works great but after i exit out of the game and dos box and go back into it to play Simon the sorcerer again i get a message that DIGPAK sound driver is unloaded and will not run the game again i don't understand why its doing this and i need help if anyone can give it thank you.
Reply 2 of 13, by Antnyhay
its after i get it installed that it says sound driver unloaded when i try to run the game again
Reply 3 of 13, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post your exact mountings
post what is written after you mounted
post content of "DOSBox Status Window"
enclose your dosbox's config file
is this a cd game?
Reply 4 of 13, by Antnyhay
My dosbox version is 0.73 and i got it of this site
my operating system is windows 7 home premium
processer is a pentium dual core t4400
3 g of ram
and a conexant high definition smart audio 221 sound card
i mount both c:\ (hard drive)
f:\ (cd drive)
then i install the game from the disc doing f:\install
it installs on c:\
to play the game i type simon while on c:\
The game plays
after i exit out of dosbox and go back in i mount c:\ again and type Simon and the following displays in the dosbox
Creative Labs Sound Blaster 16 - copyright (c) 1994, THE audio solution:3.40
EMS exists
XMS exists
UMB linked.
Sound driver unloaded
nothing comes up in the status window
the con fig file i suppose would be C:\SIMON>
the game is a cd game but installs on the hard drive but is a ms-dos game
i hope that's the info you wanted
Reply 5 of 13, by Antnyhay
i meant i go dosbox from dosbox.com
Reply 6 of 13, by robertmo
Note 1: It is highly recommended that you always use C and D for the emulated drives. It doesn't matter what your real drives are.
If your "DOSBox stuff\MyGame" folder is located on say your real F-drive, then do a mount C "F:\DOSBox stuff\MyGame"
If your real CD-ROM drive is E:, then do a mount D "E:\" -t cdrom
Note 2: Unless you are prepared to re-install and re-configure the game, DO NOT CHANGE the way you mount the C and D drives for this particular game.
Reply 7 of 13, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 13, by Jorpho
Actually, it works splendidly with ScummVM.
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
As robertmo said it works splendid in DOSBox without the need for a non-genuine interpreter.
Reply 10 of 13, by Jorpho
Well, if Mr. Antnyhay is having that much trouble, it doesn't work that splendidly.
Besides, the "fast" mode offered by ScummVM in this particular case apparently makes for a much more pleasant gaming experience.
Reply 11 of 13, by wd
Rank DOSBox Author
DOSBox Author
He didn't answer yet if the given recommendations work. So doesn't sound like too much trouble.
You could play some latest 3d shooter if you want pleasant gaming experience.
Reply 12 of 13, by djp
Maybe you should try the GOG version, unless you're a purist 😀 $6, I think.
Never try to outstubborn a cat. - Lazarus Long
Reply 13 of 13, by Antnyhay
just wanna say thanks i tried and tried using dosbox but kept getting that sound driver unloaded. Thanks jorpho for recommending Scummvm took litery secnds and worked thanks for all your help as well.
