What about MIDITEMP stuff?
Reply 20 of 29, by gerwin
gerwin wrote:
aleksej wrote:
I'll make such a photo if you need it.
I would appreciate that.
Thanks for the recordings. the songs that I listened too sound properly balanced, though with their own touch. Any luck on the photos that you intended to make, so I can see the -12V supply system?
Reply 21 of 29, by aleksej
Oh, i'm completely forgot about my promise, my bad, sorry. 🙁
In next one-two days i'll make it for you.
Reply 23 of 29, by gerwin
Thanks a lot Aleksej! now I just hope that the wireless service in my hotel is up to the download size. 30%....
Reply 24 of 29, by Cloudschatze
Guess it's time to finally chime in...
Miditemp's DoX-BoX is flawed.
Somewhere in the circuit board design (that I've yet to determine), is an improper ground that results in 50/60Hz ground-loop hum in the audio output.
This likely isn't something that would bother most people. I, however, have temporarily resorted to using isolation transformers between the DoX-BoXen and sub-mixer, like any self-proclaimed weirdo would do. 🤣
Reply 25 of 29, by gerwin
Thanks for sharing that warning.
Earlier in this thread I was talking about +12 Volt to -12 Volt conversion. Some part of the doxbox is doing this voltage conversion. I don't know how they do the conversion here, but I do know that the 'common oscillator voltage inverter method' gives audible interference in ranges much higher than 50Hz.
Reply 26 of 29, by Cloudschatze
Wave Blaster Rack
Yamaha + E-mu + Korg + Ensoniq
Reply 27 of 29, by skel2raw
Bumping an old thread but I really like the idea of putting wavetable dbs in those Miditemp DoX-BoX cases. This way one can easily switch between different dbs.
Does anyone know, where I can get these DoX-BoX cases? It seems they are not sold anymore and I can't even find one offer anywhere.
Reply 28 of 29, by Salient
skel2raw wrote on 2021-02-08, 11:09:
https://www.serdashop.com/CHiLL2
Reply 29 of 29, by cyclone3d
The Chill2 would be my recommendation as well.
There are a couple other options out there as well... but not in production anymore.
Anteg EasyMIDI EM-100 which comes with a Dream based daughterboard.
KORG NX5R - originally came with an XG compatible DB
KORG NS5R - can add a DB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
