filipetolhuizen wrote:Running glide wrappers in dosbox is tricky, I still haven't figured out how it works.
Huh? No it isn't. Install Gulikoza's build, edit dosbox.conf, install the game (+ Voodoo patch if necessary), config+start the game. What's tricky about that?
Some games are problematic though. Tomb Raider for instance works very well, just finished it some days ago. Archimedean Dynasty (aka Schleichfahrt) on the other hand won't work at all in GLIDE mode.
On topic: according to MobyGames, Carmageddon and the Splat Pack are DOS games. I didn't read all posts in this thread but I suspect the error message is thrown by the installer. Solution: install the game with the DOS installer (should be in the disc), or if there is no DOS installer use a VM to install the game.
Oh, and btw, Mr. Zaxxon: please calm down and take a few minutes before hitting that "post" button. I can understand your arousal but be calm. Review your text and correct the horrible spelling and (mostly non-existant) punctuation, and then post it. This might help us because we'll be able to actually understand what you're writing.
In one of your harder to understand posts you're writing something about you having a version of the game with dgVoodoo already included/configured. I can't believe that the game has been officially distributed with this setup.
