ecs failure
First post, by ratfink
Some months back I built a cheap machine to try out windows 7, mainly cos i bought a pre-release copy of win7 as I wanted to try to get us more up to date [i only go xp last year... we had 2000 as our most modern os until then 😜). I bought a cheap mobo/cpu combo and added a gfx card that was on offer:
ecs 6100pm-m2
phenom x4 9350e
hd4850
dvd drive
2 ata hd's
+ ata and scsi cards for various reasons
Compared to our xp system [asrock alivedual mobo, 7800gs+, x2 5400] this had better graphics but was real slow on multi-tasking. Alt-tabbing from WoW gave a black screen for maybe 10 secs.
Anyhow, recently it started to freeze and reboot randomly. I swapped the PSU, reverted to o/b video and tested the ram extensively in another box. Also shifted the hard drives. None of this h/w seemed faulty. I took out the ata and scsi cards too.
Over the next week or so, the board refused to boot more and more often [fans spin, nothing else] and then it would claim problems with the dvd drive.
I reckoned it came down to cpu or mobo, so I got a gigabyte mobo and a sata hd [as by now the hd's had been re-used due to WoW addiction 🤣].
The new system flies, some of that is doubtless the sata drive but I'm struck by how crap the ecs was even when it "worked".
I'm wondering, is there any way to work out what went wrong with the ecs board? Do the symptoms suggest any particular component on the board? Could it have been caused by the psu in some way?
Reply 1 of 6, by Tetrium
IF it was/is the PSU, I'd suggest testing the voltage rails. Also, what PSU were you using? Better to be safe then have a broken PSU break another mobo.
Also I read your ecs board uses an nvidia chipset. Those don't have a good reputation anymore. Same goes for ecs imo.
Reply 2 of 6, by ratfink
PSU is a Blue Storm II, which seems to be a middle ranking brand/ model. It's 550w I think. how do i check the rails?
The reason I mentioned the PSU is that this was the PSU I used with my asrock/X2 system once upon a time; that developed a reboot/freeze problem that I thought I had solved[there was a stick of bad ram], though there were still some very intermittent bsods i think but i put those down to messed up nvidia driver installation at that time. Since shifting that to a different box/psu it's been rock solid, but i also changed hd's and dvd drives.
It kind of worries me that although the x4 system with the ecs ran fine albeit sluggish for some months, it eventually developed symptoms that paralleled those of the x2/asrock system at one point.
Looking back I also had a 6800gt fail, but I don't think I used that in the ecs board (and it had been intermittently failing for a year or two). Probably irrelevant.
Reply 3 of 6, by Old Thrashbarg
Capacitors on the motherboard, most likely. ECS tends to use cheap caps, and cheap caps tend to go bad, with the same symptoms you're experiencing.
Nvidia doesn't have a good reputation for chipsets, but the 6100/6150 was one of the few they actually got right. I wouldn't say it's any less reliable than similar chipsets from AMD or Intel.
Reply 4 of 6, by ratfink
I recall now that I checked the psu voltages with a voltmeter when I started puylling the system apart, and all were ok. I also remember hwmonitor [on the ecs system] reported the 12v was giving 5v when the ecs board was dying but I assumed it was some software/sensor incompatibility.
Also the psu has been more heavily loaded for the last few weeks in another system. So [despite the reservations that prompted some of my post] I think I've convinced myself the psu is fine.
Bad caps eh? I didn't realise that might be an issue with modern boards, though come to think of it the gigabyte box makes great play of the tough capacitors they used for my new board.
Reply 5 of 6, by Old Thrashbarg
It's not nearly as common of an issue as it was ~5 years ago, but yeah, it does still come up from time to time, especially on cheap boards. If your board is similar to the Gateway version (a couple of which I've had in for repair), it's probably the 1800uf 6.3V caps around the CPU.
Reply 6 of 6, by nights
man ECS is a shoddy brand I have a pentium board so far from them that runs perfectly for the moment but tons of them are CRAP
you seem to think that instabilities are due to chipsets. pentium via and sis chipsets yes are slow... but they're really stable nevertheless... stable as intel ones
