Fallout 1
First post, by MIKEISTKRIEG
Sup, this is my first time using any of this emulating stuff.
ANYWAYS, everything downloaded fine, I used all the right folders blah blah blah..
But for some reason, none of the cutscenes or cinematics from Fallout will play. Like at the main menu when you hit "intro", nothing happens.
Halp?
Reply 1 of 11, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
post your mount lines and what is written under every mount line
post what is written after you type "mount"
Reply 2 of 11, by MIKEISTKRIEG
0.74, and right here http://www.dosbox.com/download.php?main=1
Windows XP
Um. I don't really know. I'm not too tech savvy.
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG: Generating default configuration.
Writing it to C:\Documents and Settings\Owner\Local Settings\Application Data\DO
SBox\dosbox-0.74.conf
CONFIG:Loading primary settings from config file C:\Documents and Settings\Owner
\Local Settings\Application Data\DOSBox\dosbox-0.74.conf
MIDI:Opened device:win32
Current Mount Drives are:
Mount Z is mounted as Internal Virtual Drive
Reply 4 of 11, by MIKEISTKRIEG
..did I do something wrong? Are you implying that I redownload DOSbox?
Reply 5 of 11, by robertmo
have you red the guide?
Reply 6 of 11, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Follow the steps in the guide.
AFAIK, Fallout run also under Windows.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 11, by TomJeffersonJones
much much MUCH easier to run Fallout 1 in windows. Don't forget to browse the mods at no mutants allowed as well.
Reply 8 of 11, by Gadget2006
I think the ease of use under Windows is a very temporary thing - it may change with the next version of Windows or even with the next service pack for Vista or 7. Knowing that the thing runs in DosBox is a nice thought, too bad GOG.com does not ship DOS files with their release of the game.
At any rate, I successfully converted my GOG.com Fallout installation (for Windows) by downloading the Fallout 1.1 DOS patch, then copying dos4gw.exe, hmidet.386, hmidrv.386 (for memory) from other games I have to the fallout folder (FO1 is supposed to have dos4gw v1.97), and some manual tinkering with fallout.cfg to set up the sound because sound.exe, which was apparently used to set up the sound in the original DOS version, is nowhere to be found legally in either the Win edition or the official patches. I got it to run under DosBox 0.74 - I had to set memsize to 32 to get it not to crash after the first "loading" screen, otherwise it then ran perfectly at full speed.
Reply 9 of 11, by leileilol
When I tried Fallout in DOSBox, the cutscenes and intro worked fine. I didn't do anything special to get it to work.
Are you playing a rip?
Debian's fucked
Reply 10 of 11, by eL_PuSHeR
It seems he isn't. He got it from GOG.com
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 11, by robertmo
the question was to MIKEISTKRIEG
