How to install MS-DS6.22 in DOS-BOX
Reply 20 of 26, by Floppy
yeah i see the dos folder and the remaining system files in the mounted c:
Guess then DOS 6.22 has installed......yeah
Thanks a ton folks, keep helping novice people, u guys are doing a great job with DOSBOX. I can't imagine why i didn't try DOSBOX earlier, great for DOS games and a must have application.
one small question why do i give 512,63,16,20 in the imgmount c d:\c.img -size 512,63,16,20 -fs fat cmd cause after calculating 9MB for c.img which come to only 9216 KB or 9437184 Bytes. Cause i plan to remake and give 20MB for c.img.
    5.02 KiB
Reply 22 of 26, by Floppy
No i hvn't made it Active, is it necessary and like, how do i make it active.
how is this DOSBox_Megabuild5-win32-installer.exe v0.73 any different than the official v0.74. Reading through the manual now.
Reply 25 of 26, by ADDiCT
No, we don't need a tutorial.
DOSBox doesn't need DOS, which is one of its major advantages. Downloaded MS-DOS images aren't supported anyway because they are illegal.
If you want to see a tutorial, go ahead and write one.
Reply 26 of 26, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Keatah: You need to actually look at what we got in the forum. Take a good look at the titles of the dosbox specific forums...
Did you see it? Yes, there is a forum called guides... Maybe you find the guide for this in there...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
