First post, by lambda2
Hi guys.
I'm trying to play this game, I can't really do it, I tried so much things and get so sick of trying that I decided to register in your forum and get some help from you.
I did everything you told to do:
- Downloaded DOSBox 0.65;
- installed the program in C:\ path and created a folder for my games in the same directory;
- put the game (riddle of the master Lu) in folder: "C:\OLDGAMES\RIDDLE";
- opened the DOSBox and wrote the following codes:
"MOUNT C C:\OLDGAMES
C:
CD RIDDLE
INSTALL (game started installing, all going well until here)
It finishes installing the game, and the DOSbox tells me to run the game by typing "Masterlu" in the window. I do it, but when i type it, it gives me the following error:
FATAL ERROR ENCOUNTERED: File not found […]
File not foundERROR CODE: 0x0800
CODE FOUND IN: MASTER.M4E
OFFENDING EXE: RIDDLE.EXE
SOURCE CODE INDEX: ..\FILEIO\F_SYSFIL.CPP:519
PATH TO EXE: C:\RIDDLE\DESCRIPTION:
HASH FILE NOT FOUND:
Do you know what's wrong here? What do I need to do??
By the way, I don't have any CD of the game, I got it from a tracker, so I just have the files.
