First post, by Crittaz
Ok so i followed the instructions by installing vmdsound, restarting, extracting launchpad to the vmdsound folder and instalind. but after installing launchpad and restarting, there is no new option when i right click dos files. So, how do i get it to install? ive tried uninstalling both and doing a clean install, but with no luck.
Reply 1 of 4, by Snover
Hurray for no system specifications!
Hurray for poor description of problem!
#1 - what is your OS? very simple question. been over this millions of times before.
#2 - "installed" HOW? Ran install.bat? Tried using REGSVR32 manually? What? WHAT?
Yes, it’s my fault.
Reply 2 of 4, by Crittaz
sorrry forgot
Windows xp pro
umm.. well yeh i did run install.bat.. i followed the isntructions.
i have installed/uninstalled launchpad and vdmsound twice and still no luck. how do i use the REGSVR32 manually
Reply 3 of 4, by Nicht Sehr Gut
Originally posted by Crittaz umm.. well yeh i did run install.bat.. i followed the isntructions.
From here?
Do you have Administrator's rights?
Reply 4 of 4, by vladr
Nicht Sehr Gut wrote:
From here?
...and make 100% sure the game you try to run is a DOS (not Win3.1/9x) game or else no, nothing will show.
V.
