First post, by Marrr
OS: Linux Fedora 6, with pretty standard set of packages, including kernel-2.6.18-1.2798.fc6 and SDL-1.2.10-6.2
DOSBox version 0.74, but saw this little problem in earlier versions as well
The problem is that in full-screen mode Hercules graphics mode (720x348) is rendered using 400-line mode (probably 720x400), leaving blank stripes at top and bottom.
Hercules text mode is rendered using 350-line mode (probably 720x350), ie. it looks perfect.
Any fix for this bug? Or perhaps this is supposed to be a feature, I don't know, for some non-standard Hercules graphics mode?
