First post, by signofzeta
The game can't run without the drive being in C because it will say problems execving hexen.exe, which I think is stupid, but the other problem here is, how do I run hexen deathkings of the dark citadel's deathmatch only maps, that is map33 to map 38 by using dm? Because the dropdown list, that is, I couldn't input the map numbers myself, shows the original hexen maps, and not the maps for the expansions.
Oh, another problem is that, when I exit the game, instead of the path name being hexdd, it says hexen instead.
so it seems that deathmanager defaults to c:\hexen, and not d:\hexdd, which I think is stupid as well.
Reply 1 of 2, by bloodbat
I think Hexen included a stupid readme that lists command line parameters, including -file and -warp which might help you.
In any case, read this stupid site:
http://doom.wikia.com/wiki/Parameter
And you might find what you're looking for.
Reply 2 of 2, by RaVeN-05
Use Source port Like GZDoom (best for single playing).
Or use Skulltag (best for public multiplaying through internet and LAN)
http://grafzahl.drdteam.org/
http://skulltag.net/
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
